Timing Belt Kit Questions.
Blackicz
40
Nov 4, 2002
Friend of my have a 2G timing Belt Kit, {water pump kit, Tensioner & Idler Bearings, Timing Belt Tensioner/Idler, Blancer Timing Belt, O-Ring, Oil-Seal Camshaft, Tensioner, Blancer Timing Belt, Timing Belt Tensioner Adjuster] all this comes with the kit, i was wondering would it fit the 1G? thanks!!
The water pump will not fit, the idler should fit but the 2g tensioner pulley I got from Mitsu was bigger than the 1g one I had..it didn't fit, so I used the 1g one. Are the o-rings for injectors? Those are the same, I would assume the camshaft oil seals are the same as well. The timing belt tensioner (the one with the pin in int) will not fit a 1g...they have different bolt patterns that bolt to the front case.
