timing belt install problems... marks not lining up
mattn
128
Jul 24, 2002
Ok, I didn't #### with the blance shaft belt, because I'm only doing the timing cuz i have to put in a new water pump. Yes, I ####ed up and didnt put on in a year ago when i did the 60k mile maintenance.. anyways, now I put the t-belt back on and the top 2 camshafts match up on every revolution of the crank, but even after 6 turns the bottom marks dont line up. do i just have to reposition the crank to the timing mark and then that will be TDC? and then position the other sprockets (oil pump, etc) to line up. And then go ahead and throw the t-belt back on and make sure it doesnt skip a tooth or someting.... or is my problem with the balance shaft belt? I didn't think it would be necessary to touch the balance shaft belt considering it didnt need to be replaced.. any help would be greatly appreciated. I've been working on the project for 7+ hours and would like to have it completed tomorrow.. thanks in advance :)
i had the same problem with my 1.8 laser i would set the timing marks up exactly and then it would be off, you really need to check the balance shaft cuz thats what was throwing mine off, does the car run? if not then its probably the balance shaft. check the balance shaft timing and try again. and make sure your tensioners still good, did you change that at the 60k? or now with the new t-belt?
here's something you could try... pull your spark plugs out, and insert a very long screwdriver down to touch the #1 piston, find the spot where it would be at TDC and check your timing mark(s). if its at TDC and the crank timing mark is right but the cams are off, pull the t-belt and reset the cams. Check it out and report back :)
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
