Timing? and head knock.
hwmptwtguk
May 22, 2008
lawton, Oklahoma
I recently had my timing belt and pulleys done by a local DSM expert. The car would run and drive fine before i had this done. There has been a slight knock comming from the head which i suspect is the lifters? Since the timing has been done the car will crank over fine and start but it will get to 900 RPMs and then putter out. Can this mean that the timing is off? And is the knocking the lifters like i suspect? the knock gets louder as i get in higher RPMs.
  • Wanted 6 bolt NT water pipe
    • chrisman287
