time to replace head gasket
Well, if you do it right, you'll probably be resurfacing at least the head. The machine shop may take some time, unless you buy a head already prepped.
The actual wrench time isn't much, it's more the care with which you do it. For your first time, expect to spend at least half a day on it. Probably 6-8 hours.
Just dont rush it make sure you take your time and follow the directions, and replace all timing parts and you should be good to go, vfaq.com is a great start.
You can also buy it seperately as well. Im about to replace my Headgasket and headstuds for my new turbo but from what I know unless your block has lots of knotches and what not in it you might not need to resurface it just use a composite HG from felpro or the mitsubishi oem one.
-aRMIN
if youre replacing your head gasket are you just going to rebuild the whole top half? if so just order a head set and a timing kit and youll get all the stuff you need belts gaskets water pump and such
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
