1G Tial wastegate.. What am I missing?
Jiggalude
284
May 14, 2005
Lancaster, Pennsylvania
I have the tial wastegate shown in the picture. It attaches to the exhaust manifold. When I bought the car the precious owner had some dented rusty dump tube. My issue is since it faces straight down that any dump tube that I've come across will just point back towards the engine. Where am I getting a new correct dump pipe.
And I forgot to put the pic in so here it is.
Nothing wrong with it dumping to atmosphere, your looking for a recirculated option youll have to custom fab something into your down pipe. If it's off your manifold, if it's off your o2 housing vendors like punishment racing have such things.
Search "flexible wastegate pipe". Idk how well they would hold up but here's one i found with a 38mm adapter.The other end as you can see wouldn't be necessary unless you wanted to recirculate
http://www.ebay.com/itm/35mm-38mm-W...-Gaskets-/321830774241?_trksid=p2054897.l4275
There's plenty more and some more DIY type hoses that are more spiral like the vibrant brand.
http://www.jegs.com/i/Vibrant+Perfo...AEixeQHGRanvl_e6ef-6vy4XqCji5M4TUcaAuMa8P8HAQ
Other than that just get a 38mm flange, some pipe, and get one welded up. Should be an easy job.
