Tial 44mm Wastegate/Aem Tru-boost
Andy123
93
Sep 24, 2008
Mississauga,
Running a 44mm wastegate, have a red spring. ~10 psi.
The turbo is a e316g, wanting to run 25 psi.
I have the aem-tru boost controller.
Now when setting the wastegate to crack option on the aem controller whats the preffered option for my setup? And do i need bigger springs?
Thanks!
Thanks!
If I recall correctly from some instructional videos I saw on YouTube, you want to set it about 2-3 psi before the rated pressure on your waste gate spring so that by the time it opens completely you are at set pressure and you don't boost spike.
You don't need a different spring, just that higher springs tend to give you slightly more boost response. But no big deal.
