2G Throttle Cable replacement
Fatcatpaddy
Jun 7, 2012
Napa, California
Hi everyone,
My throttle cable snapped (the short cable that runs from the cruise control to the throttle body) Ive called all my local parts stores and can't seem to find one anywhere. I need the car up and going ASAP, does anyone know where I could find a cable for my Talon fast? The car is a 95 Eagle Talon with 2L turbo. Your help would be appreciated
On the other hand I just installed these new gauges and am looking forward to seeing them work :D
https://www.dropbox.com/s/dobvfe6hyvpe0zw/2012-11-10 16.13.04.jpg
Thank you!
Those 2 vendors didn't have the cable for with cruise control, would it be possible to bypass the cruise control and just get a non cruise control cable?
On my first 1g I just used the cable that went from the pedal to the cruise control and made my own bracket so I could use it only as my throttle cable. If you have a piece of metal laying around that you can make something out of you could try that.
Other than that check a vendor or junkyard for a non-cruise cable.
