Throttle body coming loose
jkimes
250
3
Aug 25, 2004
Fayetteville, Arkansas
The four bolts that hold the throttle body to my intake manifold are coming loose after hard driving. I have a custom 2.75" upper IC pipe connected to a bored (62mm) NT throttle body via a 45 degree silicone coupler and Tbolt clamps. Should I helicoil the threads on the intake mani and use some bolts with some sort of thread lock to keep it from coming loose after heavy boost? Any suggestions would be greatly appreciated. Thanks. :aha:
is the throttle body coming loose because the bolts are loosening up when you drive hard?
Do you have the correct bolt size? Also with aftermarket elbows, the flange might not be as thick as other eblows, so you need washers. I know I needed them with the ets kit to make it snug and tight.
If the manifold is stripped you can re thread the holes, but if it was stripped wouldn't it not tighten at all?
