Clicking sound coming from throttle body?
skapegoat
39
Dec 4, 2012
gering, Nebraska
1992 n/a. When I have the key on and motor not running there is a clicking sound coming from below the throttle body. From what I can tell it is probably the idle speed control. Is it supposed to make a clicking sound? I've also have been having problems with the idle at cold starts and it won't stay running when up to temp. Is the isc something I have to replace or can it be cleaned? Is there adjustment to it?
No , adjustment or cleaning isn't possible. Sounds like it's a good time to replace it. It'll give you exactly the issues you're having. You could always pull it out and test it before jumping for a new one if you like.
True, the only way to test it is ust a resitance test. Not bulletproof, but a start. I believe it says in the Hayes manual what it should be but it's been so long I could be mistaken. Honestly there's not a good chance that the noise your hearing is coming from anything else. I'd just source a new or known good IAC sensor and go from there. Worst case you'll have a new sensor that'll last you years. Never known a TPS to make any "clicking" sounds, I can't think of anything on the throttle body itself that woulod either. And the IAC's are pretty commonly bad or failing.
