Throttle body bolt
mattspyder
1,046
Nov 2, 2004
del taco, Wisconsin
Im trying to figure out what thread size the bolt is that goes in where the Throttle body coil pack is. the bolt that keeps the throttle caple (when you let off the gas its the coil pack that opens the throttle body) anyone know what the thread size is? mine fell off the other day and now the car will die sometimes.
Its not the BISS screw.
let me know if you need more info. Ill try and get a picture
Matt,
I assume you mean spring where you say coil pack. Are you talking about the nut on the throttel shaft that holds on the throtthe pulley or the bolts for the adjuster on the intake manifold?
This might require a picture to get your point across.
Steve
