throttle body and intake removal...
yukiz
458
4
Jun 17, 2009
Bay area, California
is there any guides to disassembly intake manifold and throttle body?
i mean i did removed the throttle body, but i couldnt remove the intake....
i searched whole forum, but came up with nothing.....
any help will be appreciate....
thanks...
to remove the intake you need to unhook all the vac lines, plugs, throttle cable. Then the fuel line. ?Jack the car up and place on jack stands. Reach up behind the motor and unbolt the top portion of the intake. Then go back up top and remove it. Then unbolt the fuel rail and remove it. Go back under then and undo the 6 bolts/nuts (i think) that hold the intake to the head then go back up top and undo the rest.
Edit i fogot about the support brackets that also need to be taken off when your under the car. You can just leave them off when you reinstall it.
If memory serves me correctly, you only need tot aka the fuel rail off if you are removing the entire IM. You can leave the fuel rail on if you are only taking off the upper IM, like if you were taking your upper portion off to be ported.
  • Wanted 6 bolt NT water pipe
    • chrisman287
