And_44
- 835
- 8
- Feb 13, 2010
Marysville,
Washington
Ok, I've been searching for a bit and couldn't find anything on the forums but was curious.
I know how to use the helicoil and drill, tap, and install them I do them all the time at work. Only problem is at work we use SAE (Boeing aircraft) and work pays for their kits.
My problem is, can you use a tap from a tap/die kit for a thread insert? I need to repair the threads for my exhaust manifold to head studs. I have 3 m8x1.25 and 2 m10x1.25 and trying to figure out what size of tap to use for the inserts. I have the correct drill sizes to drill the holes.
The kits with their taps are pricey, $45 for the m8 kit and $60-$70 for the m10's.
It seems rediculous to spend that much just for a tap.
