Another smoke thread :\
dr1ftx3
398
3
Jul 4, 2005
Hoffman Estates, Illinois
Well guys I've been lurking around various smoke threads trying to pinpoint my exact problem but still to no avail. Here is my situation: I'm fresh off a professional rebuild, the last one walked. The engine's got about 800 miles on it and I've been babying it still since the rebuild. Well about 100 miles ago I started burning major oil....but it only seemed to happen when I was coming to a stop. No white smoke on idle or anything, its when i'm rolling to a stop sign after driving for a bit and I take it out of gear. BOOM. Smokescreen. It smells like oil and not coolant, and theres no blue tint. I took off my intake pipe and there was a little slick of oil in it and just a dribble on the turbo, but the turbo has no shaft play at all, and the car pulls when I do boost it. Thing is, the car has not really been tuned well yet.....so what i'm wondering is, could it still be the turbo even if theres no shaft play? And could the car not being in tune really cause such an amount of oil being burned? Any ideas?
hey, i know u mentioned a professional rebuild but did you re-torqued the head bolts after a short period after it being built???
I had the Exact same problem! Mine started at 400 miles though. It was indeed my turbo. I don't recommend continuing to drive it like this. The smoke problem will only continue to get worse. Make sure you watch your oil levels vary carefully! If its smoking how mine was your burning quite a bit of oil.
