This many error codes? With Log
jeff24680
223
6
Jun 2, 2008
Allen Park, Michigan
Is it possible to have this many error codes and the car run completely fine with no knock(even though im getting an error for this sensor as well) great AFR's, and seemingly no problems. I am getting these as reported by EvoScan 2.6
Throttle position sensor
ISC motor position sensor
Engine coolant temperature sensor
Crankshaft position sensor
Camshaft position sensor
Vehicle speed sensor
Knock sensor
Injector circuit
Fuel pump relay
EGR sensor
Ignition coil
Ignition circuit
My only issue right now is after warm up/driving when ever if I am in neutral my afr will almost always hover around 16(15.6-16.5) sounds Lean to me, but according to this log all my idle controls seem to be functioning normal and I am idling at a perfect 750-780, WOT is a perfect 10.8-11.4, and cruise AFR is a perfect hover of 14.5-15.3. The log hear shows idle right before 2 mild throttle presses and return to idle. MOD List is UP TO DATE
HTML:
TPS	RPM	TA	AirFlw AcelEnrch O2     O22	ISC	IdleSW
0.115	750	7	31.25	37.6	0.761	0.156	7	0
0.115	781	3	31.25	37.6	0.722	0.156	7	0
0.115	750	6	31.25	37.6	0.781	0.156	7	0
0.115	750	4	31.25	37.6	0.742	0.156	7	0
0.115	750	7	31.25	38.4	0.742	0.156	7	0
0.115	750	7	31.25	37.6	0.703	0.156	7	0
0.115	750	5	31.25	37.6	0.683	0.156	7	0
0.115	719	7	31.25	38.4	0.625	0.156	7	0
0.115	750	5	31.25	37.6	0.644	0.156	7	0
0.115	750	3	31.25	37.6	0.586	0.156	7	0
0.115	750	7	31.25	37.6	0.508	0.156	7	0
0.115	781	3	31.25	37.6	0.429	0.156	7	0
0.115	750	5	31.25	37.6	0.293	0.156	7	0
0.115	750	4	31.25	37.6	0.234	0.156	7	0
0.115	750	4	31.25	37.6	0.156	0.156	7	0
0.115	750	6	31.25	37.6	0.137	0.156	7	0
0.115	750	4	31.25	37.6	0.176	0.156	7	0
0.115	750	5	31.25	37.6	0.195	0.156	7	0
0.115	750	4	31.25	37.6	0.195	0.156	11	0
36.897	750	6	56.25	62.7	0.410	0.156	24	1
65.632	969	5	143.75	103.5	0.820	0.156	37	0
20.805	1719	17	168.75	69.0	0.839	0.156	40	1
12.759	2250	29	112.5	40.0	0.449	0.195	31	0
8.161	2375	32	75	25.9	0.156	0.195	25	0
0.115	2406	32	50	18.0	0.117	0.195	17	0
0.115	2344	32	43.75	15.7	0.117	0.195	10	0
0.115	2188	31	37.5	14.9	0.098	0.176	6	0
1.264	2000	19	37.5	16.5	0.098	0.176	13	0
23.103	1781	26	68.75	35.3	0.078	0.176	25	0
33.448	1844	26	125	55.7	0.078	0.156	35	1
33.448	2156	28	156.25	57.3	0.176	0.156	35	1
33.448	2594	30	168.75	51.8	0.761	0.156	35	1
33.448	2969	32	168.75	46.3	0.820	0.176	35	1
33.448	3219	32	162.5	40.0	0.839	0.195	29	0
0.115	3375	33	62.5	14.1	0.859	0.195	23	0
0.115	3250	33	43.75	11.8	0.859	0.195	15	0
0.115	3031	33	37.5	11.0	0.722	0.195	8	0
0.115	2750	23	37.5		0.527	0.176	15	0
0.115	2563	23	37.5	12.5	0.332	0.176	19	0
0.115	2313	22	37.5	14.1	0.156	0.176	7	0
0.115	2094	20	37.5	14.1	0.137	0.176	6	0
0.115	1875	18	31.25	15.7	0.117	0.176	6	0
0.115	1688	15	31.25	16.5	0.098	0.176	6	0
0.115	1469	17	31.25	18.8	0.078	0.176	6	0
0.115	1313	20	31.25	21.2	0.078	0.176	6	0
0.115	1219	22	31.25	23.5	0.078	0.176	6	0
0.115	1156	22	31.25	24.3	0.059	0.156	6	0
0.115	1094	21	31.25	25.9	0.059	0.156	6	0
0.115	1063	20	31.25	26.7	0.059	0.156	6	0
0.115	1031	18	31.25	27.5	0.078	0.156	6	0
0.115	1000	16	31.25	28.2	0.508	0.156	6	0
0.115	969	15	31.25	29.8	0.820	0.156	6	0
0.115	969	14	31.25	29.8	0.839	0.156	6	0
0.115	938	12	31.25	30.6	0.859	0.137	6	0
0.115	938	13	31.25	31.4	0.859	0.137	6	0
0.115	906	11	31.25	31.4	0.859	0.137	6	0
0.115	906	10	31.25	32.2	0.878	0.137	6	0
0.115	906	10	31.25	32.9	0.878	0.137	6	0
0.115	875	11	31.25	32.9	0.878	0.156	6	0
0.115	875	9	31.25	33.7	0.878	0.156	6	0
0.115	844	10	31.25	33.7	0.878	0.156	6	0
0.115	844	9	31.25	34.5	0.878	0.156	6	0
0.115	844	8	37.5	34.5	0.878	0.156	6	0
0.115	844	8	31.25	34.5	0.878	0.156	6	0
0.115	844	7	31.25	34.5	0.878	0.156	6	0
0.115	844	8	31.25	34.5	0.859	0.156	6	0
0.115	813	9	31.25	35.3	0.859	0.156	6	0
0.115	813	8	37.5	35.3	0.859	0.176	6	0
0.115	844	8	37.5	35.3	0.859	0.176	6	0
0.115	844	6	37.5	35.3	0.839	0.176	6	0
0.115	813	7	37.5	35.3	0.839	0.176	6	0
0.115	813	7	31.25	35.3	0.820	0.176	3	0
0.115	813	8	31.25	35.3	0.781	0.176	3	0
0.115	813	8	31.25	35.3	0.820	0.176	3	0
0.115	781	8	31.25	35.3	0.820	0.176	3	0
0.115	781	7	31.25	35.3	0.820	0.176	3	0
0.115	781	8	31.25	36.1	0.800	0.176	3	0
Do i need to replace all these sensors? Like WTF
As far as I know, the ECU has never been changed so it would be a 99 ecu, I know it is at least a 97+ because it works in evoscan a reports with MUTII with very good speed.
Might I add all the work in my profile was done in one complete 30 day session.
I.E.
-Engine and Trans pulled,
-Did engine work while waiting for arrival of trans
Attached trans back to engine and dropped it back in, removed emissions and plugged everything back in, broke the smaller coolant temp sensor and replaced it with one that a local guy had, I have unplugged and plugged all sensors back in. Reset the ECU twice, I am just so confused as to why so many sensor are giving me warnings but yet the car is running almost 100% perfect minus the idle AFR that I also can't figure out, so was just wondering if the two were related
Check the alternator output. If the volts are low the computer will start throwing a bunch of bogus codes. It gets "stupid" at low voltages.
So I tested the alternator through EvoScan and it is constantly above 13V, at idle when I turn lights and ac on its drops slightly below 13 then recovers, I just replaced the negative post on the battery and made sure everything is fastened down securely, I bought another 4 ga ground wire and I want to place it somewhere, currently I have
1-battery to firewall
1-negative post of battery to starter
1-IM to firewall
These are the ones I am positive of I heard there is another that is supposed to go from tranny to chassis but I am not sure if it is plugged in. Where do you think I should put this other ground wire? I was thinking somewhere near the front o2 sensor to the cross member or front frame.
Does anyone else have any ideas as to why so many errors would come up yet the car runs at 95% right now?
Yup, I just cleared them before work this morning and they came back by the time I got home, wierd sometimes they all appear and sometimes they dont, MOSt of the time they do.
Any ideas?
**UPDATE**
Here is a picture of my terminals right now just for soem reference
pie that was what i was going to ask. if they do come back start with the frist error and try to fix it. and just go down the list. check wires double check everything.
Any ideas?
there has to be a falt in the wires some were. inless you evo scan is falty? can you get another ecu and put that in and see if that fixes the problems.
98-99 Ecu's are hard to come by if anyone has oen for sale let me know :), and I guess I can do that its going to be a bi***, but we'll see. I guess I can start by checkign the wiring however I have unplugged and plugged all connectors back in already.
i figered they wouuld be hard to come by, i didnt know if there was anyone in your area that had one. do you have a voltmeter if so you can do a continuity test.
I figured out what my problem was.
When using evoscan there are multiple protocols to retrieve CEL codes
Simply put, I had MUTII EFI selected when I should have had OBDII EFI selected did this and now all CELs except my boost control solenoid and EVAP are gone and thats becasue those two are not plugged in.
Thanks!
