This is how you measure exh manifold pressure.
This should improve the signal quality of my exh manifold pressure channel on the M800 without electronic signal conditioning! Running 4 taps into a damper chamber with the sensor instead of only one in the collector is a def improvement in data acquisition!
Now you bring this up after our conversation.
Very clean install. I wouldn't have ever thought to go through the flange like that.
I'd love to see a before and after difference of the data that you gather. Meaning this configuration vs. from a single point on the manifold.
I have mine into the upper bolt hole that used to hold the turbine heat shield. Its right at the opening of the housing. It reads, but not very stable.
http://www.dsmtuners.com/forums/dsm...tealing-14b-record-build-7.html#post153279927
Any results from this setup yet? I'm curious to know if this works better them a single port on the collector of a manifold.
I'm going to test this soon. I have an FP3052 w/ 44mm wg, and a header mounted wg that I'll run back to back on the dyno. And just to make 100% sure of the results I have an identical header with no wg provisions.
Check out my thread, you might be able to do something like that and get your EMAP to log more stable.
http://www.dsmtuners.com/forums/turbo-system-tech/468023-those-who-logging-exhaust-pressure.html
Right on, keep us posted.
Link will go live tomorrow to be able to pre-purchase the manifold we have around 100 units before Christmas but only 20 units will be sold at the pre-sell pricing of $299.
Venture over to our FB page http://www.facebook.com/fpturbos and tomorrow I'll post a link to the product page where you can purchase the manifold and be one of the first 20 to have it in your hands.
- Michael
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
