thermal install
wags122
81
6
Jan 19, 2005
Snohomish Co., Washington
Well my thermal exhaust arrived on friday, so this weekend me and my buddy were getting ready to put it on and we came across a problem. my stock exhaust is 2.5in is this right? also the owner before me welded a 3 inch cat to the 2.5inch piping no reducer just filled the void with weld. so my question would be is there any way to remove the catback without seperating the cat back from the down pipe? also i am guessing its time for a new downpipe and cat?
thanks for your time
Your exhaust is not 2.5'' stock, its more like 2.25".
If your exhaust is 3", you could just bolt/weld/clamp the cat-back exhaust to your 3" cat and wait until you upgrade to an aftermarket downpipe that either eliminates the cat, or will bolt up to your 3'' cat.
Piranha451 said:
The Thermal exhaust is 3" but has a reducer to bolt to the stock cat. If your car has a 3" cat, you will need to have the reduced section cut off and a 3" welded in its place to match the cat.
Ahh, I didn't know that. The only Thermal exhaust I have seen was set-up with a test-pipe, and it didn't have any neckdown.
thanks for the replies i ordered a new cat and down pipe problem solved :dsm:
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
