buhay6
- 1,661
- 65
- Jul 9, 2010
Delisle,
SK, Canada
Hey fellow tuners, I'm in the early stages of my build process and having a lot of panel replacement to do but no welder and no one willing to come do my welding for me. I work a semi repair shop and our part supplies drop off catalogs for us a lot, I noticed the thermal arc fabricator 181i and was wondering if any one had one in their shop? If so is it a good machine? I like all the features and the welder at our shop said it looked like a good machine.
Here's the specifications:
Mig (GMAW) Flux-cord (FCAW) Lift Tig (GTAW) Stick (SMAW)
Rate output:
-180A/23V@23% dutycycle -145A/22.5 V @30% dutycycle
Max open circuit voltage:
62 VDC
Amperage range
10-180A
Wire feed speed:
100-650 IMP (2.5-16.5 m/min)
Cost is 950.00 not including taxes
I'll be getting my safety bonus check from work in February and instead of putting it all into parts I want to buy a welder to replace body panels first.
I've used lincoln and miller welders before with great success and learnt very quickly. In 3 months I went from being a first time welder to being as good as guys that had 3-4 years experience. Boss was so impressed he sent me for my ticket......got to the last weld where I had to fill a 1/2 gap in thin (little over a 16th of an inch thick)galvanized steel pipe in 3 or less pass's and I failed because I left a pin hole gap!
But that was 5 years ago and I haven't welded since.
Link to the welder:
http://victortechnologies.com/thermalarc/products/detailProduct.html?prodID=W1003182
Rate output:
62 VDC
Amperage range
10-180A
Wire feed speed:
Link to the welder:
