B-lackGSX99
- 112
- 2
- Nov 9, 2006
Edmonton,
My current symptoms:
1) Black exhaust / oil on front passenger side of motor.
2) Idle surge at idle (1000 - 1250 rpm jumps ever second)
3) Loss of oil.
4) White smoke coming out of tailpipe when stopped and at operating temperature when on the accelerator.
5) Temp gauge maxes out. (only let this happen once, and temp becan decreasing after 5 minutes).
The mechanic had begun preparations to change my head gasket, and install some arp head studs. He was surprised to see that the old head gasket is in good shape and does not appear to be blown anywhere. He also mentioned that there doesn't appear to be any coolant mixing with oil anywhere. And I don't think it's happening in my turbo (20g), because it doesn't have a coolant line going to it...
We have decided to get the head pressure tested for any cracks, as we do not think that there is any potential for ring / valve seal damage. He also mentioned to me that the head does not appear to be warped in any way. Basically, if the pressure test doesn't show any cracks, then i'm just going to install the new head gasket (OEM) and assume that maybe the studs weren't torqued down hard enough. I think they are supposed to be at around 85ft/lbs right??
Does this sound like a reasonable course of action?? Any suggestions or comments??
3) Loss of oil.
