The Elusive Rear End bolt part NO
SplitGSX
38
Jul 30, 2004
Evansville, Indiana
Here is the rundown. 92 GSX LSD ABS 4-bolt.
In the back of the rear diff you see the fill plug. Directly above that plug there are two bolts. Almost making a triangle. Those bolts go through the upper portion of the suspension. I am missing one of those bolts.
Satan has no idea what the bolt is, they can't find it on the parts fiche. Dodge/Chrysler dealer has no idea. None in the junkyard. I cannot find this part in my FSM on CD.
Does anyone know the part number for this bolt?
After staring at CAPS for about 20 minutes I *THINK* you need:
MB515260 : BOLT, DIFF RR MOUNTING FLANGE, 12x28
Just to confirm, you are referring to one of the 6 bolts that connect the differential to the rear subframe right? It should be two on top, 1 on each side, and two in the back (the ones forming a triangle).
Sounds like exactly what I need. Very appreciated.
