nanokpsi
- 623
- 8
- Jan 28, 2004
tha dirty souf,
Texas
DJpHGotBanned said:Andy, your explanation does not make much sense. A Evo3 turbo can be used and wont necessarily be over taxed with the higher RPM. This isnt a belt driven supercharger. Turbos dont care what RPMs the motor turns. They only care about CFM. Now if you rev your engine at a boost which equates to more CFM than the Evo3 turbo can handle, then you will start to have issues.
Andy is right on the money. Turbos have a flow limit as I'm sure you are aware. In building a motor to rev to 10k you are undoubtedly running big cams, head work and a smim as well. Those things combined with 10k rpm will surely outflow a measly 40-42 lb/min turbo. Actually, a evo3 can't even keep up flow wise on a stock longblock 2g with cams and a smim.
To further clarify, you could still do it with a 88mm crank and 156mm rods and a standard style piston. I've always thought they were "super long" 162mm rod motors though.
