Tensioner pulley w/o beam style t.wrench
thereef
100
Oct 5, 2010
Wichita, Kansas
So I'm trying to finish up this job this evening & getting the car started. Hopefully.
However I need a "beam style torque wrench" according to VFAQ. I'm curious if there's an easier (aka cheaper) way of doing this SAFELY?
The step in question is 29 on this write-up The Infamous Timing Belt TSB
Thanks guys!
Torque wrenches are for squares, I never use them, when its that important they get gauged for stretch. Just put a good amount of tension on it, the important part is spacing on the hydraulic tensioner rod. I use angled snap ring pliers to set the pulley tension, using a small tool will ensure its not too tight.
