420A Tension pulley problems
Dragon 3259
84
19
Jun 4, 2022
Tucson, Arizona
Has anybody ran across the problem that I'm having here, where the tensioner pulley screw snapped and your belt is loose. I do have a replacement coming soon however I'm stuck trying to figure out how to remove this or loosen the tensioner pulley enough so I can pull my power steering pump.
The bearings blew out, the belt is loose however but not enough. Anybody got an idea about this and how I can fix this problem. Sadly I'm on a time crunch, I have to take the pump in to get the warrantied pump replacement and I only have 6 days before they send the part back.
Is that the A/C tensioner?
No it would be the serpentine belt tensioner I probably should have put that in there the first place I have a 2G 98 GS and that is the main tensioner for the entire belt it's directly underneath the power steering pump.
That's a very common problem. I've sold 7 of these on Ebay. It will almost always break when overtightened.
I removed my tensioner assembly entirely on the 420A car and run a shorter belt. The power steering pump pivots forward and backward quite a bit when the bolts are loose. Using the pump as a tensioner is fail proof.
You'll probably have to use the car like it is now. Either wait on the tensioner to get delivered or order the correct belt length for a tensioner delete and wait on that to get delivered. It won't hurt anything to run without this belt. The alternator has a separate belt, but you will have heavier steering.
