Temperature that OEM fans turn on in a 2G
XSNRGGST
159
May 26, 2007
Tucson, Arizona
I have been following the different threads on this subject. I was wondering at what temp the engine fan turns on in a 2G. I recently installed my Flyuidyne with dual 11" 810 CFM Spal slim fans. Today while I was stuck in Phoenix traffic on I-10 temps hit about 230o. I have read different information on when exactly the fan kicks on. I will be doing the VFAQ "cooling fan relay bypass" very soon. On this FAQ it states that 210o is the temp the ECU turns on the engine fan. Is this correct?:confused:
I was gonna say 210ish, it in the area somewhere. Check out your connections, and fuses mayby you have an issue with the way you have it wired in. Also check the polarity you could have the blowing the wrong direction, unless you know they are not kicking on.
I hate toggle switches though if your cool with em do what you want :D
