In Cabin Fans wont turn on? O_o
Status
Not open for further replies.
elementalwindx
745
5
Aug 13, 2003
Wilmington, North Carolina
After replacing all my belts and my head on my 90' Plymouth laser turbo I went to start the car and of course everything starts and runs fine except when I go to turn my ac on, the compressor turns on and you can kinda feel cold air seeping out but the fans will not blow the air out. Anybody have any ideas? I've checked some of the fuses but they "look" clean. What fuses do you guys think it could be if it is the fuse?
ok I guess nobody has had this problem and possibly knows the answer. I guess I'll just spend a good amount of time digging thru the service manual and very closely inspecting every single fuse. BLAAAH! :mad: :barf:
The circuit for the blower motor isn't that complex. Take your multimeter and wiring diagram and start at the motor working backwards, or find where the power starts out and work to the motor.
I can't imagine it would take longer than you've waited for somebody to tell you the answer.
Steve
Status
