1G TB Ground Strap HELP
Adrian97
5+ Year Contributor
100
Mar 3, 2018
Göteborg, Europe
Hello!
On my throttle body i am missing the ground strap for the IPS, how would i go about replacing this?
i am missing this
The bolt holding the throttlebody on accomplishes the task
Hello!
i am missing this
Per above it doesn't have to be that specific strap. Piece of wire will do
No on a stock turbo t-body setup the throttle body is generally electrically insulated by the gaskets on each side of it, yes the bolts could touch inside the holes, but it's not a solid connection, so the ground strap is needed.
No feedback to the ECU for the throttle stop switch.
Since it's not clear to me what the OP has for a vehicle I'll just point out that on a 2G the IPS is inside the TPS and gets grounded from the same ground pin as the TPS so the throttle body ground isn't used/needed. On a 1G the IPS is external and is grounded via the Throttle Body it's screwed into thus requiring the TB to be grounded.
Thank u guys :)
So i can use wire like this ?
