Take a look at these spark plugs
E-CLIPS97
295
Jan 8, 2003
Eagle mountain, Utah
Hey,
Tell me what you think of these spark plugs. Quite a bit of white smoke coming from exhaust. Once I drove it for about 10ish minutes, the smoke wasn't bad while driving, but would come back a little bit at a stop. I am planning to have the motor rebuilt regardless, but can someone give some insight on the condition of these plugs?
When I pulled the plugs, there was oil and goop on the threads. You can also clearly see the insulator is burned. Car drove fine otherwise with no hesitation or anything. Drained the oil, no coolant in it (though I did see some sparkling metal flakes...:sosad:)
Thoughts?
Do a leak down test, should let you know if your rings are shot (speculation on smoke, and oil on the threads of the plugs). As for how the plugs look, I am sure someone else will chime in about those.
Edit - I would also do a compression test.
I might be way off base here but
Lack of maintenance -Spark plug well seals bad, bit of oil fills the well
Judging by color, been like that a while, possibly overdue oil change?
If so, check the PCV valve too.
Stick with coppers, leave the 'inum products to the other cars that use them stock. There's not much gain there other than extended service intervals.
http://www.dsmtuners.com/forums/frequently-answered-dsm-questions/233421-spark-plug-faq.html
Its possible that this car was not maintained well...I just bought it on the cheap and it was clearly in need of many things. With the metal flakes in the oil and the white smoke coming out the exhaust (with a light oil burning smell), I am thinking the condition of the plugs would be an indicator of something....fun. LOL
Yea the shavings in your oil is not good, also it looks like the valve cover gasket was leaking oil into your spark plug wells. Address the metal issue first because that can go south really fast.
Surely oil comes with glitter and metal flakes now? Right? But No might want to look into your bearings maybe tear apart that used oil filter too see what its caught, whats the color of the flake?
The flake color was almost a gold or brass color. They were very very small flakes though.
