Spark plug wire impedance...?
kergilman
207
Oct 25, 2007
Portland, Oregon
So I am checking out my plugs and wires yesterday and looking @ my Haynes manual, it states that all 4 plug wires should ohm out to about 8k for impedance.
The plug wires I have for cylinders 1, 2, & 3 ohm out at about .5k and cylinder 4 @ 3.5k. I used another DMM and returned the exact same results. Do I need new plug wires already or am I missing something here...?
Anyone else have a reference...?
What you are measuring with your meter is DC resistance, which is different from impedance.
Either way, as long as there is continuity in the lead and there are no breaks in the insulating jacket, you are good. The output from your coil travels as an electro-magnetic pulse over the surface of the conductor, so the value of the measured resistance (or impedance) really doesn't effect the ability to spark.
Spark plug wires have fairly high resistance to suppress the emission of radio frequency noise. Some people believe that lower resistance wires are better because they will conduct more power to the plugs but since the transmission is skin-effect, there is no truth to that.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
