1G Tach doesn't work correctly
My1GLaser
1,565
34
Dec 4, 2006
Bartow, Florida
My tach is 300 rpm off at idle and about 1200 off at Redline. What could be causing this? I have been having this problem for a couple months now. It is consistent and hasn't changed at all over time. I did a total rebuild on the car and everything seems to run fine, except for a few idle sputters here and there. I am comparing the info to the RPM in DSMlink, which I have been emphatically told is correct. Please help, it is hard to drive this thing at WOT while looking at the tach and doing addition, or trying to watch my laptop log.
Yes, thanks. I read it before, but there was never a reply with the part number. I need something to go on here. I have no idea what to look for, and there isn't anything on the throttle linkage. It might be somewhere on the maniflod, but not in the "normal" spot. I did have to reroute both original harnesses, but used a plain accel cable to get rid of the cruise control. I need a clearer description, part number, picture or some idea of how it is wired so I can follow wires to see if it is somewhere. What feeds the tach its signal that this thing "filters?"
My problem is that my rpms jump all around at 3-4k They start jumping around and if i get it on it they go down to 0 and back up. Wtf?
i am have the same problem with my talon my tach is off by 300+/- rpms but i have an avc-r hooked up and i get a perfect reading off the screen of the avc-r thats how i know my tach was incorrect any info would be great
when i put a 91 ecu in my 90, it did the same thing, i would hit about 3-4k and it would drop to zero, check the ecu, they have different ways that the tacks hook up.
I was told to cut pin 109 i think and it would solve my problems, but I never cut the wire. I'm kind of afraid to do it, but maybe I'll man up and try it out.
If you have the original '90 ignition (coil, PT, ECU, tach noise filter, harness) the dash tach gets its signal (via a white wire) from the tach noise filter which gets its signal through another white wire from the coil pin 3 (which also goes to ECU pin 109). All other years are different.
Better not do that or your fuel pump won't work. ECU uses signal on pin 109 to know engine is running/cranking so it will turn on fuel pump. That is why just turning key to ON with engine not running/cranking does not power the fuel pump (safety measure).
Rallye,
I do have the all the original ign system. Thanks ALOT for that info. I will check out the wiring this weekend.
As for this point you made, it gives me an idea and a question.
I lose all fuel pressure within a few minutes of the car being shut off, and I wish that the fuel pump primed for a second or two just before cranking. Can I run a signal wire to pin 109 from the fuel pressure solenoid, so that it gets power with "key on, car off?" I know it has power in key on, but its 12v. I guess I could just probe the pin 109 source wire under the hood and find its voltage and get a matching "key on, car off" source (in case its 5v) Just double checking with someone who knows these cars...this is my first DSM.
There is a white wire from coil 3 (closest to firewall) to the "tacho interface." There is another white wire that runs from the other side of the tacho to the harness end of coil pack. That harness runs to the large harness for the Transistor. I don't know if the white wire goes to the transistor then the ecu or just thru that "bundle" of wires and straight to the ecu.
The question of whether or not it goes to the transistor before the ECU is so I can eliminate or include the PT in the troubleshooting. That damn thing is expensive!
Is this "tacho interface" the noise filter that you are referring to? It is bolted to the back of the coil pack. I do see one other white wire coming out of coil 3 (both wires are more like off white, which I guess is a 17 yr old white wire?), but it goes straight to the coil harness plug and into the same bundle of PT wires.
I don't have a 90 so I can't tell you what harnesses the wires physically go into or what the device order is when a wire goes to multiple places. But I do have 90 wiring diagrams and I can see that none of the tacho interface wires go into the PT. As my post #8 states, coil pin 3 goes to one side of the tacho as well as ECU pin 109. The other tacho side goes to the instrument cluster pin A12 (tach). The tacho casing must be grounded (bolted to engine or something directly bolted to engine like a coil pack) or it won't work properly (is this your problem?).
yes
This is the noise filter on a 1990.
While it's no longer necessary to change all of the 90 ignition system to allow it to work with a 91+ ECU, http://www.ecanfix.com/~mdhamilton/ecuconversion.html is still a great (and perhaps only) reference on the unique wiring found on '90 DSMs.
This is the tachometer sender on the bottom of a '90 coil pack, shown with a 91+ coil pack for comparison.
On the 91+ cars the tachometer sender is part of the power transistor module.
Steve
HOLY MOLY, FINALLY!!!! OF ALL THE POST I READ ON THIS SUBJECT (1990 TACH DONT WORK..) SOMEONE FINALLY SHOWED A PIC OF THE PARTS.
THANK YOU steve DSM Wiseman
I LIGHTENED THE AWD UP BY GETTING RID OF ALL THE UNNESSECARY BRACKETS AND STUFF.. WELL THE BRACKET FOR THE MANIFOLD TO ENGINE IN BACK HAD THE NOISE FILTER ON IT AND I PITCHED IT..
GOT ONE FROM JUNK YARD.. WALA... TACH WORKS AGAIN THANKS
That wire doesn't go to the PT on a 90, it splits and goes to the tach via the filter (shown above), and the other branch goes to the ECU.
If you are running a 90 ECU, 90 coil (with tacho interface), 90 PT, and a 92 tach, (your car is a 92 right?) there's your problem right there.
You need to install a 92 PT to support the 92 tach. It has a square plug with a PITA wire retainer clip on the 90, and a nice easy ovalish plug with the squeeze lock retainer on the 91+ PT.
The important part is the one extra white tach wire on the 91+ PT. Run that straight to your tach input, and run the tach wire from your tacho interface straight to your ECU pin 109 and NOT to the tach. I just went through all this with my car.
