T3 turbonetics manifold and .82a/r
91-gsx
932
11
Mar 31, 2005
San Jose, California
The turbonetics manifold was made for 5-bolt exhaust housings and requires a spacer to run the 4-bolt outlet turbine housing. I was wondering if the turbonetics manifold could clear a 5-bolt .82a/r exhaust housing without needing a spacer because the .82a/r exhaust housing is a bit bigger in size.
thanks for the help
p.s. I have another thread asking about a rev hard t4 manifold, just trying to decide between the .68a/r t4 housing, and a .82a/r t3 housing.
Ill ask at work tomorrow my boss had a 35r and ran both the 5bolt and 4bolt. But yeah you are correct at the 4bolt will not clear the block without the spacer, just not sure about the 5bolt
If you could I would really appreciate it because I would much rather a .82 a/r.
thanks for the help
By the way, what turbine housing did you run on the 35r with the turbonetics manifold and what a/r was it?
He never had a 5 bolt housing like i thought. But, with the 35r's we run the 82ar housing with the spacer plate
