Turbonetics T3 Manifold Measurement
xcelr8n
1,854
5
Jan 31, 2003
toronto,
Does anyone have access to one of these manifolds?
I just need a measurement between the mating surface to the head, and one of the turbo bolt holes.
Thanks in advance :thumb:
It almost helps...
I really do need the manifold measurement though!
For the turbo dimensions to be helpful, I would need to know for certain that one of thoes turbos clears the block & water pipe with no spacer plate or modifications.
17cTD06
It has a T3 flange.
Will be swapped out for a T3/T4 someday, but want to use it while it's still in good shape.
Thanks for the measurement!
Turns out it's the same as the stock manifold.
