t3/t4 install question
1badturbo
114
Jun 8, 2003
tulsa, Oklahoma
OK the time has come for the turbo upgrade I'm going with a t3/t4 the specs are
.50 for something I'm not to turbo smart so i don't know what these #'s are
.83ar
76trim t350 turbine wheel
to4e housing with 2.5 inlet and 2.5 outlet
56trim gt40 compresser wheel 2.41/3.22 61mm inducer and flows 65lb/min
now i know alot of you will say that turbo is to big and ask what supporting mods i have but i got a killer deal and this is only the start of my buildup and I'm currently running 550's, uicp, bov, 2.5in exhaust,safc ,boost controller,and intake, for the turbo upgrade I'm getting 255gph in tank pump, xspower manifold ,front mount,victory performance o2 housing,downpipe,clutch and tuning.
my question is when i get this turbo which i know is big to huge do i need to get slim fans or are the stock ones fine as far as clearance for the turbo
turbo here is the turbo
Yes, that is a big turbo that is WAY overkill for your current setup and will likely find it's way back to eBay when you see just how laggy it is (.82A/R StgV OMG ).
You do know that you'll need a special exhaust manifold and O2 housing to mate up with that turbo. Depending on what you get will dictate what other mods to fans/intake/IC Piping you will need.
Or you could pick up one of THESE exhaust housings which should clear the water pipe but will require "hacking" of the PS fan :dsm:
