Switching my N/T cams with Tsi cams....what are these numbers
flyinghighlm
345
4
Sep 27, 2005
charleston, South Carolina
I ahve done alot of reading on this and narrowed my search down to a set of 92-94 Tsi cams from a m/t with the D,C set appearing the be the better one. I found a set from a 92 Tsi but I do not reconize this set of numbers : I see a 21, J, 3, E, 1 A on the ex. and 21, J, 3, E, 1 H on the intake. What am I looking at????
not sure about the numbers, but I believe you only need to change the intake cam because the exhaust cams are the same for both models. someone correct me if i'm wrong.
as far as I know and from what I have read any 1G dsm will benifit from this swap, but you might wanna ask one of the wiseman or someone with alot more experiance to confirm what I think.
The swap will only work if you put them into a n/t 4g63, not a 1.8. But I'm sure most of you know that
yeppers... we're both 2.0 4G63's or at least i know mine is & i presumed flyinghigh was too. :cool:
No you only need to change the exhaust cam. The intake cams are the same for the n/t and the turbo m/t cars. They only made 2 different intake cams and 2 different exhaust cams.
On the exhaust side
the 1.3661 - 1.3585 was the n/t and turbo a/t cam and
the 1.3777 - 1.3974 was the turbo m/t cam.
On the intake side
the 1.3661 - 1.3585 was the turbo a/t cam and
the 1.3777 - 1.3974 was the n/t and turbo m/t cam
And will work for the 90 also Hope this helps.
On the exhaust side
On the intake side
thanks gsdewd, but did you mean the exhaust n/t & turbo a/t ranged from 1.3661 to 1.3858 instead of 1.3585? (likewise for the turbo a/t intake)
anyone have any estimates on what to expect the cost to be for a set of these cams? or what they paid for theirs??
so what's the significance of the numbers flying high referred to? is there any difference between the 90 & 91 exhaust cams versus the 92-94 exhaust cams??
