switched gauge clusters now no oil pressure
tazndrew04
471
5
Sep 3, 2009
Omaha, Nebraska
So it started out with me wanting to switch out the silver turbo gauge cluster for a black gauge cluster. The silver gauge cluster I had before the oil pressure was working, but since I swapped out clusters the one I swapped to the oil pressure does not rise. It stays down as though the car is still off. This is after letting the car warm up to temp. All of the other gauges work. I did not mess with any of the wires or anything having to deal with the oil pressure. Any thoughts on what may cause this different cluster to not register oil pressure?
Same thing happened to me...
I swapped a white faced cluster from my friends gst and my oil pressure gauge isnt working. My stock cluster was working fine when I swapped them.
I wonder if its a gst to awd difference or something?
The gauge in the new cluster could be..broken?
Disclaimer: What I'm about to say is based on theory and logic, but has no actual testing to prove it works, it may blow you, your car, and your dog up. Continue at your own risk.
Off the top of my head, you could apply a small voltage, say, 3 volts or so, to whatever pin on the cluster is associated with the oil pressure and see if the needle moves?
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
