scotthidley
- 154
- 17
- Nov 7, 2004
Cleveland,
Ohio
lewroe59 said:I dont know what you guys are looking at, but there is no baffle in the muffler. it is a straight-thru design. I give up, stick to your dynomax mufflers, and shun innovation. And I would have hoped an engineer would understand how the system works, but when your seeing "baffles" I guess its apparent why it didnt make sense to you.
good lord! do you not read? The point obviously wasnt that the hose was stainless, it was that the hose is THERMALLY SHIELDED(and re-routed far from the pipe). wtf, is up with you guys?
There have been several engineers that have commented on this
Bends add a huge increase in equivalent flow length. On top of that, you're putting a lot of stress on the connection to the turbo, as there's no other supports on the exhaust (don't be surprised if it cracks). Get some reflective heat sheild for the hoses that are close to it. You're not going to notice much if any difference in oil temp. Keep in mind that there's a decent amount of underbody airflow around there. It's good you're trying to do something new, but next time you need to put a little more thought into it.
