2G Swapping injector pins
deviousgst
931
Mar 24, 2008
bakersfield, California
im having a hard time understanding how to do the injector swap pins at the ecu..
my 95gsx isnt getting spark and i swapped everything already, ecu, power transistor, coilpack, timing is good, the only thing i havent done is swap the CAS. But im going with a 1g CAS instead because its an "upgrade" and mainly because i dont wanna do re- timing to get to the CAS , since on 2ga theyre located behind intake cam gear..
what i dont understand is how exactly to swap injector pins at the ecu. what wires exactly? im not good with diagrams like the one RRE has on their site
RRE Instructions
has anyone done this and if so, can you show me exactly what wires i need to swith around at the ecu (pics)
It's pretty easy, you just go by what rre says.. Pull that wire out and swap it to where needs to go
i put the 1g CAS without swapping injector pins and it started right up. only thing i had to do is change the firing order and started right up, idled perfect ran perfect. i still need to adjust the timing because i just aligned it middle wise..if any of you guys have done this did you guys HAVE to switch injector pins?
