Swapped injectors now wont fire on 1 and 3
bsbllfit7
1,104
3
Feb 17, 2009
Salem, Oregon
as title says all i did was replace my injectors and now im not getting a fire on 1 and 3. I did unplug my 1g cas and coils and have double checked them since i reinstalled. The wires are in the proper order and the 1g cas is hooked up properly. What else could be my limiting factor on why 1 and 3 are not firing. All cylinders have spark and when i disconnect the injectors through dsmlink the car still idles the same. When i pull the injector wires the same thing happens so im obviously not getting fuel through them!
Nothing appears to be bent. Is there anything else that i can check??? Just strange how i only unplugged a couple of things (2 or 3) plugged them back in and are all verified to be connected properly, and now the car wont get fuel on 1 and 3
also does anyone have pictures of what either the fic 850cc injectors look like or the 880cc pte injectors. Think i might have gotten ripped off on this forum. Trying to find out so i can file through paypal.
See if the injectors are getting any current or even connect the old injectors and see if they are doing the same thing. It could also be an ecu problem.
I'm going to switch the injectors with the 2 and 4 ones and see if the problem follows the injectors or stays there. If it stays on 1 and 3 what should I be looking for.
Sent from my HTC EVO 4G
wow just swapped 1 and 2 injectors and it is now firing on 1 and 4 instead of 2 and 4. Followed the injectors. So then i tested it with my old 550cc injectors and she fires right up on all 4! I bought these injectors off of dsmtuners and I'm extremely peaved right now. I will be making contact with the guy momentarily and telling him about the situation and that i need my money back. If he doesn't oblige he will have paypal taking the money back from him. I wont name him if he gives the money back but if not he will be named. Its 100% evident to me that they were faulty as i didnt change ANY wiring the when i swapped back to the 550s. Also i even had the ecu tuned through dsmlink for the 850s when i had the 550s back in and fired up RIGHT AWAY but didnt run right obviously tell i changed the settings.
