Suspension Problem
BoostInsideTSi
200
May 5, 2004
Aurora, Illinois
I took my 95 talon to the shop today to get it aligned after putting in my front camber kit, and he is saying that no matter what, the camber is on one wheel is still positive even after adjusting it to the max, and the upper control arm link is about a paperthin amount from hitting the inside fender, and he says sometimes it is hitting. I don't understand if a front camber kit would cause this to happen. Before I put the camber kit on I had some negative camber, but I don't understand what would cause this to happen. Any ideas?
in our cars you accually supposed to have 1.3 degrees of positive camber and mine turned out to be about 1.3 on both sides with the kits fully adjusted. Also the way i fized my upper control arm from hitting was grinding the arm down a little bit with a die grinder and then spray painting it back to black. hasnt hit since.
