SUNROOF REPAIR 2G [Merged 8-8] sun roof rail jam stuck open
wow guys i owe thanks but i feel like an idiot.......
when i bought mine the kid i bought it from was like yea u gotta push this little tab on the [assenger side when it closes otherwise it doesnt close....
i removed the tabs and that thing works like a champ...
thanks guys
Well my sunroof problem is that it flutters open when i speed over 60. It opens fine but sometimes when I go to close it, it gets stuck and I have to push the tab foward to get it closed. But I can still push up on it and it opens about s 1/2 an inch. Do you have any suggestions guys?
This is for a 2g...
bringing up a dead thread... One of my rails is not well aligned with the other one. it opens and everything but does not close any help?
Glad I seen this thread. I seen a 2g sunroof in classifides but I don't wanna risk it not working. Any places to get a new one for our 2gs
Sent from my T-Mobile G2 using Tapatalk
I noticed that my sunroof doesn't close all the way, I don't know if this helps but check the side railing and see if there are any "extra plastic peices" I seem to have found something that may have broken off when I ripped out the shade portion of the sunroof
Can someone help me , i fixed the sunroof but i cant put the screws back in ( yeah i know WT...) , they just dont hold tight the sunroof even if i put as strenght as possible they dont evenarrive to the bottom of the hole...
I forgot i want to ask , since im trying to reinstall the sunroof sunshades, the normal operation is when i open or close the sunroof glass should it move by itself the sunroof sunshades? and if so.. what must be hooked up to in order to do that, because mine doesn't...
I am having problems with my sunroof too, it wont close...
This thread has some info, however ALL the links are dead, so it is pointless unless people can post some new info.
Hi DSM Bro´s , I need find the SUNSHADE SLIDE BLOCK Eclipse g2 (1998)
Anyone can helpme to find this part? thanks!
You can try stangmurdera on here he has miller import parts here in charlotte, he usually has DSM part outs. Or your local junk yard, as far as new parts not sure.
I was able to get mine at the junk yard, ripped apart a sun roof and got just about every part extra and re did mine.
Thank you very much friend in Uruguay ( My Country ) there are not many DSM , and very few Eclipse 20 at most, I try to look for in a junkyard in USA
i find http://www.oemautopartsandaccessori...eclipse-1998/vtec/93098/pid/395463f0f9879b2e/ I think it's economic .
Thanks for your answer!
