Rear Quarter Panel Repair [Merged 11-8]
I took some pictures
How much would you charge if you were to cut out a section and send it to me?
That is a fairly easy fix, a section from the body line down to the pinch weld would work perfect, since the pinch weld seems to be intact in your picture. HOWEVER I would have a professional body shop do this repair, unless you have the skills and equipment. Using a patch repair section is the way to go rather than have a shop just weld sheetmetal in and shape it with bondo, which is just going to fall out later anyhow. Repaired correctly it should last quite awhile.
(upside down, along pinch weld)
Rust Free
