Suggestions/Pointers Needed
nytescion
602
Jun 25, 2007
Woodbridge, Virginia
well I'm getting ready to lock everything down in place. Right now i'm just sticking stuff in to check for clearance and what not so some of the IC pipes still need to be cut and painted also a few things here and there aren't connected at all. I'm on the fence about going to blow-through that why the bov is where it is. But with that said do anyone of you have any suggestions or areas for me address/pay close attention to on my setup? Also mod list in profile is up to date.
That sure is a good looking skinny radiator you've got there. I would address the rust issues on the thermostat housing. A little emery cloth will take care of that in short order. The valve cover looks good too. You said you are on the fence about going with a blow through setup or not, do it. I think most everyone will be happy with blow through after they have it all setup. Everything's looking good though, good luck.:thumb:
Port your manifold or get a new. make sure it doesn't leak also. My 16g is leaking from the mani to the turbo :-( make sure you've got a good gasket and some sealer on everything like that. Good luck to you man, it's looking very good!
