Suggestion?
DeanCorleone
44
Mar 20, 2004
Frederick, Maryland
Not sure if you guys can suggest MBC's for my car, but I'm looking for the best buy for my buck. I've looked at the Hallman Pro Series, and the Turbo XS Standard Boost Controller, I'm confused on what the Turbo XS Standard Boost Controller comes with, does it come with the complete install kit like the Hallman does? or not? From what it sounds on how they install it, its like they cut the WGA line, and the BCS line, and just plug it into the controller? Huuhhh...? I understand how to intsall a Hallman fine, and what it comes with... its another story with the Turbo XS Standard Boost Controller, but its cheaper.
Anyways, I'm not sure if you guys are even are allowed to suggest products on this forum or help me, but I need to know which would be the best path?
Home Depot MBC's work just fine, all you pay for is bling and mounting brackets. I would get a Buschur MBC if I did get one.
I just built a "Grainger" valve mbc. It works better then my turboxs mbc and cost me 10 bucks.
http://www.xmission.com/~dempsey/perform/grainger.htm
Follow the directions in his walkthrough, except I didnt go ghetto and glue those barbs on like he said, you can find fittings for the threaded end that go to a vacuum hose, for the other end (with the adjustment screw) just jam a piece of 3/16 (I think) brass or metal tubing into it, it will friction seal.
This is seriously easy to make, and for the time it takes is worth it.
Originally posted by 98RedGs
or check hallman and joe p.
www.boostcontroller.com
I personally would suggest, especially with you be FWD, is the 2B med-hi boost controller from dejon tool. I've had mine for maybe 6 months now, and I love it. You set the low and high boost(duh :p), and it can be switch easily with the flick of a switch that you can mount anywhere you want.
Of course it takes drilling a small hole for the switch, and running wires through your firewall. And the price is pretty damn good too imo.:thumb:
http://dejontool.com/DSM-MBC.htm
