Stumbling Missing Under Boost
MLEONARD
Jan 13, 2007
VICKSBURG, Michigan
I Have A 1995 Eagle Talon Awd Tsi . Rung Good Until Boost Kicks In . No Idea New To This Game.
You most likely have a boost leak. Do a boost leak test.
Mine did the same thing, had a bad leak at the biss adustment screw.
Yes run a boost leak test. Probably what it is. Also check the gap on the plugs and make sure they are in good condition!
Check that all intercooler pipe clamps are tight and not slipping off. If it still does it then you need to investigate the boost leak further.
