stuck on fuel pump reiwire. quick question!!
Aproductions
2,123
50
Aug 11, 2009
Allentown, Pennsylvania
So on my 2g eclipse I am stuck on the fuel pump rewire.
first of all the wires you cut are the 2 from the white clip right?
and the blue and black striped one is the wire that goes to the relay and the black and white one is the ground one?
I just need to know what to do with the other end of the black and white wire. (see pic for arrow)
Easy google 2g fuel pump rewire first site has detailed instructions. So the original ground is not used only the wire to the harness. You need to put the three grounds together your new 10g ground, relay ground and ground to harness. Hope that makes sense God bless bro.
