Quick Fuel Pump Question
sccrAdidas15
377
Aug 17, 2004
Lancaster, Pennsylvania
Is it normal for your stock fuel pump to whine? Lately I have been hearing it whinning, and it seems like it has been happening ever since I got my exhaust done, i don't know if it's the fuel pump but it sounds like that's where it's coming from.
You check if maybe there is a small leak from when you put your exhaust on if it wasnt sealed everywhere tight? It maybe a small amount of exhaust leaking out or it maybe the fuel pump.. Just making suggestions
would the exhaust make a whining noise though it's not like a hissing noise, and the guy did use a stethoscope on all his welds when he was finished.
well then you can ###### elminate the exhaust making that noise... But your exhaust becoming new wouldnt really interfere with your fuel pump. Another thread i read into is that some one who just installed a new Walbro 255lph fuel pump had his start whining and i believe a few people suggested that it might be that theres not enough voltage going to it.
But on the other hand yours is stock.
Yeah you should do a re-wire when you upgrade your fuel pump. I put a walbro on too and it still felt like I was hitting fuel cut, I did the re-wire, and I have no fuel issues anymore. Hearing your fuel pump shouldnt be new, they are kinda loud.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
