stroker kit
hova
38
Oct 6, 2005
orlando, Florida
:( slowboy racing has a storker kit it has a 4g64 crank and a manley rods and wiseco pistons my ? is it says the longer storke is from the crank so how much boring is my block going to need if any, because the pistons are a standard size (.020 bore, .040 bore ,etc)
need help?
If the pistons are standard size you won't need to bore any. But I would advise you away from stroking a gs-t, strokers are not fwd friendly. You will spin all the way through 3rd unless you get a lsd, prothane motor mounts to prevent wheel hop, an anit-lift kit, and really sticky tires. If it's torque you want for your gs-t go with something like weisco 9:1 pistons at .2 over. Happy DSMing
