stroker help**
1990gsx1781
190
Jun 28, 2008
Lynn, Massachusetts
ok so on dsm parts the sell a dsm 6bolt 2.0l stroker kit. i dont have to bore the cyl. right? or do i thanks guys
are you trying to stroke to 2.3L? if you want 2.3L you need a 100mm 6 bolt crank and bore depends on what the block needs .20 or .40 over. to give you a good seal with the piston rings. your machine shop can tell you what the bore size is needed. normally .20 over is done when you rebuild it to have fresh metal for the rings.
its say 2.0L but it doesn't say the stroke on the crank. i'm assuming its a 88mm crank. 88mm crank = 2.0L. there were other options like 2.3L so i say its a 2.0L. call to verify the stroke on the kit you want.
