Some stroker questions, help.....
95Eclipsers
346
Nov 4, 2002
Fairfield, Maine
Ok now is the 2.4 from the 4cyl 00+ eclipse a 4g64?
Were can i get one?
If so is it and 7 bolt, and since it is i believe does it still have the same cracnkwalk issue?
Will 1g rods go into this 2.4 motor wit either 2g pistons or wiseco?
and will this 4g64 will drop into my 97 talon tsi awd? if so is there anything i will have to change, what will i have to do to the block to make it able to support 21psi (t-28) and a 50-100 shot of nitrous wet, im not look for huge power, but somthin great on the street and somthin i can turn the bottle on when i get to the track, i know nothin about this stroker can sumone help me!
:confused:
Man the are so many questions about this just do a search. 6 bolt 2.4L came from a 89-91 Sonata, 7 bolt came from NT eclipse syders. There are other vehicles that have these engine but spend some time and use the search function you would be surprised at what it can do.
thanx for the info but htat dint help much, can i get a year, 6 or 7 bolt, and what not?
direct bolt in, will it take 1g rods and 2g pistons?
