Stroker Head
Lunch_Box
2,137
15
Mar 14, 2003
Sherwood Park,
I know that strokers don't need massive ports jobs and oversized valves but what work needs to be done to maximize your set up. I will be running a built 2.4L with a custom AGP T3/T4 T67 turbo and all supporting mods. Would oversized valves help or standard be fine? What cams would you go with; FP3, Crower 415's...? How much of a port job? 3 or 5 angle?
Thanks,
Kris
go with oversized valves and big ports...
Either cam choice would be good, but you'll definately need to upgrade your valvetrain. Ferrea NA springs would be my first choice. You'll have to shim the Crower spring kit to get enough seat pressure for those cam profiles.
3 angle is fine.
check with supertec valvetrain components ask for Willie tell him steve from dsm concepts refered you their number is 408-448-2001. those valves we use on all our 2.4's at the shop ask about the inconel exh. valves
stephen.
  • Wanted 6 bolt NT water pipe
    • chrisman287
