Stroker Build 7 bolt Crank Help.
Muzzled
34
May 14, 2011
Kitchener, ON, Canada
Trying to find a 7 bolt 100 mm crank for making my 4g63 stroked.
Ive been doing alot of research and ive had little luck locating said crank.
Any help/ advice?
I have Eagle Hbeam rods already, and pistons are on order.
im just trying to locate a 7 bolt 100 mm 4g64 crank for making my 4g63 a 2.3 stroker.
Get a forged one they are stronger then a oem stroker crank, I went with Manley and it was really nice and well balanced ( so my machinist said) right out of the box.
I agree, it maybe the best performancr route. But Not Looking for Huge amounts of hp. 450ish Is my goal and from what I have read , an Oem crank should do just that. The Car is is going to be a Summer Daily Driver.
look for a 4g64, galants have them, 3g eclipses have them ect. any 7 bolt 4g64 crank will work.
also they are plenty strong in stock form. no need for a forged crank unless you're looking for something in the 8s.
Ive Been trying to locate one, not easily found in ontario so it seems, all the local wreckers have none.
Mine is from a 2002-2003 Kia Optima 2.4L. The crank is solid and can easily handle your goals, and can be found cheap. With the Eagle rods, you will need to do some minor block clearancing but not too much.
Thanks for the info guys I really appreciate it, havent found one yet but i do know which cars they came in.
It has been a pain to locate a parts motor. The wreckers around here will not sell the crank seporately.
I called Magnus yesterday, since it is about an hour away. They might be able to source one for me so im waiting for a reply :)
Saves me shipping too depending on the price range
