street disc VS puck disk
unless you plan on all out racing i would go with a full disc. i had a 6 puck disc on my 300zx tt and it made it very hard to ease into shifts. trust me on this one you won't like it.
I agree. A street style disc would be ideal for more than 95% of the people on this site. Read this before you make any decisions.
From Road Race Engineering:
Metallic Puck Style Clutch Discs
They wont die. They can take a ton of abuse and wont turn into kitty hair. Even when they get so hot that the pressure plate warps and the diaphragm looses it's spring pressure, they wont fully die. Cool, right? The down side of that "never dieing" is that it allows them to keep slipping, then heat up and grab. The slipping with out dieing makes the surface cracks in the flywheel and pressure plate that will eventually cause the flywheel to come apart. Whether it is a stock flywheel, lightened stock flywheel or a Chromoly flywheel, puck clutches make cracks that kill flywheels, that kill bell housings and more. They have their place but I don't think in a street car. In a race car that gets regular inspections they can be fine. Also most puck clutches have a solid hub center that will contribute to horrible coast down gear noise (worse in an AWD).
Puck style discs can put up with a lot of heat. You also need to slip them more to keep from breaking things. More heat made. When a street disc is slipped too much and gets hot, it disintegrates and turns into kitty hair. You wont keep driving on an overheated street disc. If you get a puck disc to the same temp, nothing happens. That's nice because you can keep racing. But that heat is hell on the flywheel. Just like brake rotors crack when over heated, so do flywheels.
If you keep racing on a cracked flywheel, you will eventually saw your tranny in half. It does not matter if it is a lightened or stock flywheel. We get flywheels sent in to us regularly that are too cracked to use. Those guys cry like babies when they have to pay a core charge. From the cores we get, I would guess one out of ten racers are driving around with some cracking.
stick to a full face disc. After reading your profile i would recommend you check out the Spec Stage 2 or the Competition Clutch Stage 2. both offer full face discs and provide very moderate pedal pressure and an engagement that is perfect for your FWD.
I daily drive a 6 puck sprung disk...SBR 4000. It's not as easy to let it out, BUT its not bad at all...and it grabs like crazy. Its definately worth the extra headache.
I'd recommend it for all High end horsepower Dsm's.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
